Program guide issue on 722k | SatelliteGuys.US
Yespage
17,749
18,111
Ohio
I'm surfing the Eastern Arc and my programming guide on the 722k can only see one or two programs ahead, which is seriously messing up the DVR recording. My sat signals are strong enough, channels all look good.
Turned off receiver, nada.
Reset receiver. It asked if I wanted to update the programming guide. Said yes. It finished, took about a minute... it didn't update jack.
Reset receiver. Nada.
Unplugged receiver for a minute. It asked whether I wanted to update the programming guide. Same as above... it didn't update the guide.
I have the receiver plugged into the network via ethernet cable.
It is a pain in the butt, mainly because recordings don't seem to end. The Daily Show recorded for 5+ hours!
Tried the check switch, all was well. Went back to watching the tv, it started loading the programming schedule automatically and that took a few minutes. Seems to work now. Thanks!
Cutting Costs
32.0 remote learning
