Program guide lag on HR22 getting worse and worse | SatelliteGuys.US
underscore
44
On June 9 I got this email:
"You may have experienced a transmission glitch to your DIRECTV service [poster's note: I did have issues with the on-screen guide being all sorts of inaccurate]. DIRECTV has fixed the problem and automatically reset the receivers. There's nothing further that you need to do. We sincerely apologize for any inconvenience this technical issue has caused."
Ever since then, the lag in response on the on-screen guide has gotten worse and worse, sometimes several seconds in between "clicks".
Receiver resets have done no good. I haven't done the "resend signal" trick yet, though I can't see why that'd matter.
Suggestions?
30 :D
Don't really see a reason why it would be lagging, unless something is wrong with it. My big hits are connecting the AM21, recording off the AM21, and two recordings going on at once.
IIRC, there is a claim that once you load it down on series links, it can have an effect too.
I had this happen to me and was fixed but doing a double red butoon reboot . I dont know if it going to solve the problem I would call us. generally if it is running slow it because something it is eating up cpu time and if it not series links then might be something else.
HR22 with SWM Slimline compatible?
2 Weeks until install ?
