Program new remotes for my 222k | SatelliteGuys.US
Symbol
593
Puerto Rico
okay currently I have the two remote controllers that came with my 222k(learning remotes 20.0 and 21.0)
since I move the receiver to my apartment I am wondering if to avoid moving the controllers If can program a spare set of remotes(the ones that come with 625 DVR)1 IR TV1 and 1 UHF TV2 they are not learning remotes they are regular universal dish remotes
If this is possible someone please let me know how I can change the remote address on the new controllers so it can be the same as my current learning remotes
if it helps TV1 is set to rem address 6
TV2 is set to rem address 12
thanks
thank you it worked!
the dish agent did not want to explain it to me and told me to go to tech.dishnetwork.com which has a million things, the agent did not specify in what part of the site the explanation to thi was.
again thank you!
again thank you!
Now you know where to go first.;)
that site is useless unless you really know it inside out or have instructions on where to go
very confusing :confused:but still good help
now my 625 DVR remotes are working with my 222k and all I have to carry back and forth is the receiver itself, already have the same setup in both homes so no check switch is needed,also ordered a spare UHF antenna from dish which didnt cost me anything
great help in this forum compared to dishnetwork.com :)
ESPN2 to show 2 Premier League matches per week
Bare minimum HD package for someone with no HDTV?
