Programming 21.0 Remote for OPPO BDP-83 Blu-Ray player | SatelliteGuys.US
CubsWin
1,028
244
Bourbonnais, IL
I have been working on this for a few hours now and I'm not making any progress. Has anyone been able to successfully program your 21.0 remote to operate an OPPO blu-ray player?
When I go into learning mode, the remote is indicating that it is learning the commands successfully, but then the only one that ever works is Power. The blu-ray player isn't recognizing any other command from the 21.0 remote. The OPPO does have an option to use an alternate remote code for universal remotes and it does work using one of the Toshiba remote codes (per the OPPO manual), but it only has a few basic commands and won't allow me to teach any more, plus it disables the OPPO remote.
Has anyone else had this problem and, if so, were you able to work around it?
I have a different OPPO DVD player, but was never able to get it to work with a non-Harmony remote. They must use some completely different coding. I googled and found no help.
Installation on Friday - New Customer - 922 and ? - CONFUSED
Multi-Sports Package - 29 Local Sports?
