Programming remote | SatelliteGuys.US
Programming remote
Bprimm
2
Florida
Ok, I screwed up my directv remote so now I cannot control the swim box. I took another remote from the bedroom and that one works fine. Question is what is the direct tv code for my swim box and how do I program it correctly?
:welcome to Satelliteguys Bprimm!
Please explain what you mean by swim box.
You could reset the remote hold select/mute in directv mode type in 981. If that doesn't work hit select/mute in directv mode and type in 00001. See if these work.
After a 981 reset the directv device is programmed with code 00001 already. If still doesn't respond, than the receiver might be in rf mode:
1. dtv
2. press and hold MUTE & SELECT, wait for two blinks, release
3. enter 9 6 1
4. press CH UP
5. enter last 6 digits of Receiver ID #(RID), found on a sticker in the access card compartment
6. press SELECT
Directv Genie Mini Client slower than actual Genie?
NFL Network
