Project- Help Needed!!!! (satellite signal simulation) | SatelliteGuys.US
gargamel
6
Hello Everyone,
I am faced with a problem that I need help. Could you please give me any suggestion that you may have?
At work I need to test many LNBs at the one time. 20 at the time or even more.
Everything has to be done indoors.
Normally I connect the LNB to the receiver and to the dish, then find the satellite. If I get the channel I assume the LNB is working, otherwise it is not….
I check 4 different channels that are on vercial/horizontal polarization and either on one satellite or the other.
My question are:
1. How do I connect all those LNB's together. What kind of switch would I use?
I was thinking to use a switch where I manually chose which coax to test ( or which LNB)
2. How can I simulate satellite signal indoors that is low in power for LNB's
I would need something wireless I assume, but I am not sure what.
If you have ANY suggestions please post…
Thank you for reading my post
Mike
I think this is just for tunning when trying to find two satellites. i.e Starchoice users need to find two birds Anik F2 and Anik E2.....
Mike
i see...i need something more powerfull....50 units at once....
what about vireless source....
thats a tough one...I can't find anything that would simulate noise at that frequency.... am I looking at a dead end....?!
What's the difference in UHF Pro 6.0 and 8.0?
522 optical out surround 5.1 dolby sound?
