The video from the 3618 was getting a little distorted so I started to investigate. I found that the coax port on the back was loose and it would spin in a complete circle, I thought not good. Rather than send it off I thought what the hell, I can either fix of #&%^ it. I figured that the port would be held to the inside of the back with the same type of nut and washer that is on the outside. Wrong, as usual. It is forced in to a hole in a metal compartment with clamped on covers on the sides. What I discovered is that it is just sodered to the side of the compartment. I have decided that by screwing the cable on to tight broke the sodered connection. I forced it back into place and put some soder around the inside edge and a little on the outside edge, hooked it up and the video is crystal clear. I figure that it being sodered to the compartment is a way to ground it because before I sodered it the video was lousy. Anyway, it's all put back together and working fine.
I thought that this should be shared in case there are any members with a Satworks 3618 and it happens to them.
