PS/2-to-USB Adapter for 721? | SatelliteGuys.US
SpencerCat
SatelliteGuys Guru
I need advice about whether or not the followig is possible.
I have a 721, and I would like to be able to use my wireless keyboard with it. The keyboard I have was used with my old DP7200, which had a PS/2 port, into which I plugged the wireless receiver. The 721 does not have a PS/2 port, just a USB connection.
Question: Is there such a thing as a PS/2-to-USB adapter, which would allow me to plug the PS/2 wireless receiver into one end and connect the other end to the 721's USB connector?
I know, I know, it sounds goofy, but I thought I would ask.
Richard
they sell them at walmart
and yes they work, at least used to when i had a 721, about all it's good for is typing in search strings.
USB -> P/S2 devices are pretty popular, and cheap/small. But i'm not sure if there's a device for the reverse of that. I'm sure there is but usually it's not what people are looking for. If all it does it type in searches i'd say it's useless though...
Trying to avoid CSR difficulties
OTA problems
