PTAT Feature Suggestion | SatelliteGuys.US
datwell
654
4
Falls Church, VA
I think it would be nice if there were an option to turn off PTAT optionally on the weekends and resume M-F of course. Just a thought.
Why? What difference does it make? Users don't have access to the PTAT portion of the DVR anyway, so that wouldn't free up any additional space. PTAT can be manually turned off at any time (as long as it is not currently in use or about to be in use), so users could turn it off on Saturday morning and turn it back on Monday morning. Not sure I see the point of that though.
I'm assuming the reason is so they can free up a tuner on the weekend since they do not care for any of the prime time programming on the weekend. Also, by having it set up to shut off every weekend you would not have to worry about turning it off and then back on every weekend.
What we really need is a checkbox for each day so you can select whatever days you want to enable PTAT for. It would be nice to just be able to skip Mondays or something like that.
This summer I have turned it off on Saturday nights, when I have left it on, really gives you an idea of the crazy stuff on the networks
Looks like these features are coming in S215. :up
I would like the ability added for the Save Series option to be able to only save new episodes....
Exactly!
When you use the Save Series option the Hopper simply creates a series timer for you. If you edit the timer and change it to only include new episodes, you have what you want.
Subscribe from Dish Online or from Reseller?
Dish's home theatre installation ?
