Is it possible to purchase an older receiver, like through ebay, and have it added onto our existing account? We have the SWM HD boxes. Not sure the older boxes would work with what we have set up in Kentucky. Thanks o, we are with Direct TV
It has to be an R-16 or higher for it to work.
Purchasing a box on ebay or anywhere else does not put you in a 2 year contract. The two year contract is only applied when you UPGRADE your receivers through directv
OSD771 said:Purchasing a box on ebay or anywhere else does not put you in a 2 year contract. The two year contract is only applied when you UPGRADE your receivers through directv
No, iceberg's post is correct. If you get an OWNED receiver there is no 24 months agreement. But there are not many owned receivers available (particularly DVRs). Almost every receiver you will see on ebay etc are LEASED receivers. If you want to get a receiver from ebay etc get the receiver ID, and call DirecTV, ask for the access card department and they will tell you if the receiver is owned or leased.
If you add a receiver or activating a new one you're getting tacked with 24 months. Only service swaps will keep from adding the 24 month agreement.
stonecold said:Wrong again. I just bought another HR21 Pro and activated it on my account. also if you want to pay 450 dollars to directv for hr2x it will also be owned and avoid the 24 month commitment.
And that the bottom line so there.
dishrich said:If he's also in an MPEG4 locals market, that will NOT work either; in that case an H2x, HR2x or R22 are the only models that will work.
Limited time offer
