Do the splitters give you the option to add a second reciever with paying the fee? I'm sure both TV's would be on the same channel at all times, right?
Thanks for the input. I have one HD reciever & the HD Dish. So I'm sure my reciever will have more than 1 output.
Let me ask you this: If I add a 2nd & 3rd "purchased" receiver, would I only pay one $4.99 fee or two? (since I wouldn't be leasing any equipment, it's considered a mirror fee, correct?)
Do the multiswitches give you the option to add a second reciever with paying the fee? I'm sure both TV's would be on the same channel at all times, right?
Interesting topic. My neighbor just upgraded to HD from D*, and I noticed that after the tech's left they did not install a multiswith for his "Slimline Dish". When I had mine installed a year ago, the multiswitch was included. My neighbor noticed that the "Slimline" had a 'built-in multiswith'. Is this correct?? His new Mitsu 52631 tv looks great, but his RCA 52" CRT looks crappy and low signal strength. Would the multiswitch help this??![]()
Some early versions of the slimline needed a multiswitch even for a small number of tuners because of a problem. Current versions don't need a multiswitch unless you have more than four tuners, but many people report that the installer put in a WB68 anyway.
Putting in a multiswitch would not help with the PQ on the other TV. If the DirecTV receiver driving the TV has lower signal strength than other receivers, this probably indicates a cable problem. Your neighbor should try swapping the cables between receivers (or swapping the receivers) and see if the low signal strength moves with the receiver (indicating a receiver problem) or stays with the cable (cable/connector issue).
That's what I thought as well. Another problem I tried to tell him about was he switched from Comcast to D* and I believe he said the installer used the existing Comcast cable that was there and re-routed those cables to the Slimline and then to the sat boxes........, I thought this could be an issue because D* cable is supposed to be RG6 right??
If you think that is crazy just stay with 1 box!So you guys are telling me that if you have (4) tv's in your house, you have to pay (3) $4.99 fee's whether they are leased or owned???
That just seems crazy!
We have the same set and when we upgraded to HD, the image was crappy. Then I did an autoconvergence through DVI (where the HD signal was running) and it made all the difference in the world.Interesting topic. My neighbor just upgraded to HD from D*, and I noticed that after the tech's left they did not install a multiswith for his "Slimline Dish". When I had mine installed a year ago, the multiswitch was included. My neighbor noticed that the "Slimline" had a 'built-in multiswith'. Is this correct?? His new Mitsu 52631 tv looks great, but his RCA 52" CRT looks crappy and low signal strength. Would the multiswitch help this??![]()
</IMG></IMG>
Limited time offer
