Pursuit Channel now in HD on directv | SatelliteGuys.US
If you already have a HR44 which i think you said from your previous posts you are fine
In Test mode till tomorrow.
Thx much for this post...I also see that D* is FINALLY getting around to putting (BACK) up WEIU for our area...after it was D*'s fault for moving their LRF from Springfield to Decatur back in October, & NOT planning for also having to move the corresponding fiber feed that they require to pick this station up here. :rolleyes:
Pursuit channel now in Hd on directv also directv took off the SD channel just wanted to let you guys know about it saw it on AVS forum.
thanks
allen bluegras
Has it been confirmed somewhere that Pursuit is actually going HD with this move from 101W SD?
Or is it still going to be SD but in MPEG-4 format on the Ka band?
Guess we'll know for sure tomorrow ...
Sent from my LGMS550 using Tapatalk
Edit:
Confirmed, it's in HD 1080i ...
Sorry, but it was just that earlier short of an explicit statement in a press release, the TPN Map notes, or something. You can't tell picture resolution of a channel from the transponder mapping info. alone.
MPEG-4 SD and HD map info. look the same.
Smart Search issue
DirecTV App - RSNs Redirecting to Subscription Channels
