Q about firmware on Philip DSR708 / R/17 | SatelliteGuys.US
Damn Dirty Ape
22
Hi
Just got a Philips DSR708 R/17 installed. It shows firmware 3.1.1e-01-2-301... Is this that 6.2 upgrade under another number or how do I get that upgrade?
thanks
Damn Dirty Ape said:
Hi
thanks
That would be version 3.1.1e of Tivo software.
The 6.2 upgrade is coming. You will know when you get it.
Where would one find the current receiver software revision then?
cueman98 said:
Go to "messages and Setup" then "system information" it will be listed in there
Found that, it only lists the 3.1.1 tivo software the poster above mentioned.. No other firmware listed.
How to stop TV2 recording in Dual Mode from TV1
D* with 5.1 Surround Sound
