Q-Box block analog feed? *QAM Expert needed | SatelliteGuys.US
civicbeater
62
In orbit
I have a 12 ch. analog head end system at a property with a QAM overlay. I'm running into a problem with scanning the 12 analog channels onto the 622. I can scan them fine on the 381 (which doesn't use a qbox). It appears that the qbox is blocking the analog feed on the line as the 622 will only pick up frequencies off the QAM system.
I believe this to be true or is there a work around that you may know of?
ALL VIACOMS HD ARE ON !!!
How to ?: get vip622 output BOTH HDMI & Component?
