Quali-Tv 1080IR | SatelliteGuys.US
Quali-Tv 1080IR
satcustomer
304
California
Just received the above receiver and hooked it up to my television using just regular a/v cables (red and white for audio and yellow for video), but the problem is that the picture is bouncing up and down the screen. The video format options on this receiver are 1080i, 720p, 576p and PAL. I tried 'em all and nothing solved my problem. Any suggestions?
does it support ntsc ? if it doesnt, your tv will need to support pal. or use hdtv compatible tv and cables (dvi, hdmi, or component, unsure what the ird supports)
What I listed above (1080i, 720p, 576p and PAL) is what this receiver supports. Also, after I connected component cables to my HD television, I got no picture whatsoever.
Scalar Ring for my BUD
Dish Sizes
