Well, as a plasma guy I know very little about LCD's over the last few years so I have been researching current models. Here is what I have learned, basically, for edge lit LCD's:
Blooming, banding, flash-lighting, might as well expect some. To be honest, when Ive owned LCD's in the past, I never watched them in a pitch black room anyways. If calibrated correctly for a higher light output, using a small lamp gives you better perceived blacks and the LCD will be plenty bright.
Off angle viewing, none are great when you are used to plasma. From what i read though, it wont be a big issue for me. We sit roughly 12.5 feet away, in a scenario similar to a 3 cushion couch centered to the screen, and we sit on each end.
Being these are all 70", they are all going to be Sharp panels AFAIK, since Sharp appears to be the only ones making a 70". I imagine that matters little in final performance of the panel.
So here are the models:
Sony 69.5" (diag) W850B Premium LED HDTV KDL-70W850B
MSRP $2899
Should be out mid March
Edge lit
Motionflow 480
No Triluminous on this model (little agitated about this)
This "wedge" design bothers me with regards to wall mounting
Sharp AQUOS Quattron+ (Q+) - SQ Line
$3100 MSRP for 70"
March 2014
Quattron Plus for using extra subpixels to improve the resolution of an HD display (extra Green and Yellow pels)
HD content upscaled
3D Ready
Able to handle 4K/24
Id assume this is the "new" 800 series, so it should be a 240hz panel. From reading about Sharp, Id prefer the 240hz panel IMO.
Revelation Tech Promo Video
Im not sure Revelation and all that nonsense, it is nice for the price that it upscales 720p/1080i/1080p and can display 24hz 4K content. For the next 12-24 months, this may be a good cheaper solution until 4K works itself out a little more.
Article with some images
http://www.techradar.com/us/reviews...s/sharp-aquos-quattron-plus-tv-1212692/review
Vizio 70" P Series
http://ces.vizio.com/p-series.html#skip
MSRP is $2899 IIRC
This one is very interesting for me because its UHD, its a great price and its full array local dimming (64 zones). 64 zones does worry me and I dont think it will be something outstanding. I had a 55" with 96 zones it was good, not great. All being said its a UHD at an excellent price.
No idea when this will be available.
Samsung's 2013 8000 is a nice set, and they will have a 70+ inch in 2014, but I do not expect the cost to be anywhere near my range ($3000).
At this point, I'd say the Sharp Q+ is at the top of the list, but Im going to wait to further see how things shape out. one note about Sony however, their "W" series always reviews well and calibrates well. One problem with calibrating the sharp is the yellow sub pixels reduce color accuracy and what you can do with them. This is a factor for me.
MSRP $2899
Edge lit
Motionflow 480
$3100 MSRP for 70"
March 2014
HD content upscaled
3D Ready
Vizio 70" P Series
MSRP is $2899 IIRC
