Question about adding a fixed dish | SatelliteGuys.US
SATisfied
286
Lineboro, MD
I have a motorized setup, but have never been able to get G10r. I am planning to mount a fixed dish with a universal lnb, and tie it into the diseqc switch on the motorized dish. If I switch sats how can I get it to not turn the dish, or is this not possibel? I mean if I have the fixed dish set to lnb 2 for G10r, and I switch sats it's going to turn the motorized dish, which I don't want it to do. I would just like to be able to instantly go to the fixed dish for G10r. Any input appreciated.
in the menu setups for G10 select diseqc 2 (according to what you put this will be on diseqc 2) motor disable or off
On my Pansat 9200 I have options for Disable, 1.2 & USALS
G10 is set to disable and the dish stays where it was. SO I can flip between G26 & G10 quickly :)
Traxis DBS-3500 or Mercury II
Help With My Reciever
