Question about D*DVR and disk burner | SatelliteGuys.US
sloweddi
10
NorCal
Howdy,
Prior to actually getting D* w/DVR I am doing a little research. As a veteran, I help out a lot of other disabled veterans with their TV viewing needs. A small group here can not afford the extra fee for digital programming (Sci-Fi Channel) so on Wednesdays, Fridays, and Saturdays I set the VCR and record shows for later viewing.
Now that I am moving and getting D* with DVR, I thought it would be nice to cut the shows I record to DVD.
1. Does D* DVR have a hookup to allow this
2. What DVD burner would you recommend.
Please be as simple as possible as I do not know all the numbers and terms yet.
You can hook up a DVD recorder between a DVR and the TV just like you would a VCR.
I happen to have a Pioneer DVD recorder, and have been very happy with it, but I'm sure there are lots of choices out there that would fit your need.
Thanks everyone
I am looking at a bunch of equipment on ebay. There seems to be a glut of equipment for sale. Some DVD burners, some DVR/ burners/ Tivo basic.
I don't like "swiss army knife" electronic boxes
moonman said:
You might consider a combo DVR/DVD-burner player..takes the extra gear out of the
loop(note the Tivo fee is extra 12.95 month or 299 yr lifetime)
http://www.tivo.com/2.1.2.asp
Not worth it to give up the DirecTivo -w- dual tuners, IMHO.
You cannot edit Tivo-recorded material before dubbing from the HDD to DVD; that is possible with a separate DVD recorder.
Also, if one function dies (DVR or DVD burner) you have a more expensive box to replace.
I also do well with a separate DVD Recorder (that also has a hard drive).
Mexico?
Robert @ value Electronics.
