Question about equipment I had installed | SatelliteGuys.US
TxDTV
89
34
Texas
So Dtv came out and put in a genie in my room and a wired mini in a spare room, the model number is hr54-500
, is this the same as the 700?
I just went from a HR44 to a HR54 and the main differences (aside from 4k support) are the video outputs on the back and the front lights. Menus, speed and hard drive space are exactly the same. Oh, and the red reset button is on the right instead of behind a hidden door on the front.
The cpu and hard drive are exactly the same
isnt there a new version of the hr54 that got rid of the esata port?
i seem to recall something about that
The 500 I got makes a constant noise like maybe hard drive? Like when you first turn on your computer, is this normal, they say it is
AT&T Filing More AT&T TV Trademarks
