Question about FM Transmitter | SatelliteGuys.US
vacationsuperstar
Hey all
I need some help.
If you are using the FM Transmitter with Sirius, is it better to use higher frequencies on the radio?
Has anyone noticed a difference between say 88.9 or 90.1 and higher like stations in the 100.0 or 103.3 range?
You need to use whatever is available in your area. Search around until you get the clearest signal.
Im in a large city, so its none of the available frequencies work for very long before getting interference.
anything about switched video and more Hd?
Jamo Problem
