Question about HD DVR and Question about HD Receiver | SatelliteGuys.US
Nemesis7782
15
Louisiana
I plan on ordering the Choice Package from Directv tomorrow and I will have it hooked up on 2 TV's. TV 1 will have the HD DVR and TV 2 the HD Receiver.
Question 1. Can anyone tell me which HD DVR I will be getting?
Question 2. Will an HD Receiver work with a Standard Def. TV? TV 2 will be in my bedroom and it's a standard def. TV. I do plan on buying an HDTV for my bedroom later on down the road but for now I have to use a standard def. TV for the bedroom.
As long as the tv has at least composite connects it will work fine. As to what model dvr, it's whatever is next on the pile at the warehouse. If he doesn't bring an HR24, you can ask if he has one on the truck.
I believe it has two composite and one component. And I'll definitely ask him about the HR24 because that's the one I want. Thank you for your help!
You should use the component connections. It won't be hd, but better than using the composites.
Component carries HD just fine ... it's just not digital.
Yes, thats the connection you want to use if HDMI is unavailable.
Don't forget, you'll need the Red /White connection for audio.
Different SWM LNB setups
Olympics on Directv
