Haven't used either one. Perhaps you missed the part where I wrote that "I wouldn't be caught dead with either one". I say this from the viewpoint of a telecommunications engineer who's worked with satellites for nearly 40 years. In the old days, yes. I had a one-way satellite internet connection. I hated the fact that it relied on dial-up for 1/2 of the communications path. Couldn't wait till the first two-way satellite internet hit the streets. Went two-way, never looked back. One way is dinosaur technology.grohgre, did you ever used skyfx or skyway. if so, how does it work.
Then it's a no-brainer. If you can't get dialup, neither SkyFX nor Skyway will work. Period.i have checked and the only service i can get is satellite.
Be careful about accepting that claim at face value.now i find out that i can get sattelite service wthout any contract. .
Typical polemount charge is $125, more if the guy has to come a long ways (set pole first day, come back to install dish 2nd day). But if you're already making plans to obtain equipment, why not get the pole and a few bags of Quikrete while you're at it? Get an 8 foot Schedule 40 two inch (ID) galvanized steel pipe. Two inch Sch40 has a 2.375" outside diameter, which is a perfect fit for the HughesNet mounting bracket. Planted 3 feet deep also gives you the minimum 5' mounting height required by Hughes.if i have my own equipment do you know how much the installer will charge to install the system with a pole.
Limited time offer
