Question concerning receiver setup for new install | SatelliteGuys.US
tyanW
3
Hi,
I'm considering moving over to Dish Network from Adelphia. Here in CA, they offer the AT60 with locals channels for $29.95. When I "build my dish" online from their website, they suggest two DISH 322 dual-tuner receivers for a 4-room setup.
Question: How do I change channels in the rooms where the receiver isn't located?
Thanks,
Jon
thiggin2 said:
The second tuner(s) is controlled with a UHF remote.
Hey thanks for the quick response!.. Just to clarify, the UHF remote is useable while in the 2nd room? (apart from the 1st room's receiver)
Jon
Jon
Well, it is UHF, which is radio. It isn't line of sight like infrared.
Yep, it will reach the other rooms just fine... In fact, I have had my neighbor change my channels a few times... (Which is easily fixed by choosing another remote "channel").
Philips Pronto w/ Crappy 921
811 and JVC DR-MV1S DVD-R/VCR
