Question for installers. | SatelliteGuys.US
Smwoodward
259
Alabama
I'm getting read to start a centralized wiring project where cat6 and rg-6 is all centralized in a closet for easier installs and neater look. I haven't started the work yet, but one issue that I have come across that might happen is fire blocks. I have run wires through walls many many times in commercial buildings that generally have metal studs and no fire blocks. I also know I can make a pumpkin cut into the sheet rock right at the fire block, drill a hole and fish it there also, but I have all ready finished painting and really don't want to do that. So, does anyone have any advise on how to deal with fire blocks without cutting the sheet rock?
You can use a long flexible drill bit to drill through the fire block, then tie the cable(s) to the flex bit and use the bit to pull them through the wall at the bottom.
This is your best option if you have fireblocks. 6ft flex bit with a couple more 6ft extensions will eventually get you down into the basement.
If you have a good stud finder you can run it sideways up a wall and see if it finds a fire block
Sent From My Samsung Hercules
2 questions on HD VIP722K dual channel DVR - timers and inactivity
Oh boy.. Here comes that merger talk again...
