I did that once when I installed my DirecTV system. Had a 19" TV that I used. Brought it and the receiver into the backyard and set it on the patio about 15' from the dish. This was a (1) satellite dish and using the numbers D* gives, we got a signal right off the bat. Fine-tuned it using the TV...iafirebuff said:or you could take the receiver and a tv out and do it that way.
boba said:As a professional I find that a very poor showing for the new customer. I am sure if either D* or E* managers saw that being done by their installers that installer would not be working for them.
brad1138 said:I have to echo what boba said, there is no good reason a professional installer would not have some type of meter. Maybe if he forgot it at his last job, but you can buy a cheap meter at Radio Shack for about $20. Buy 2 and have a spare. I personally use a Birdog meter(about $400), which tells me which sat I am locked onto and has signal meter at least as accurate as the onscreen sat display.
The problem is that there are some not so reputable companies that hire "installers" ( I use that term loosely) that roll in their own cars, usually not licensed or insured and poorly prepared/equipped.
I have heard stories of an installer coming to a job with a ladder duct-taped to his roof, or needing to use the customers ladder and/or drill etc...
IMO a prof. installer should roll in a company vehicle or at least a clean work van/truck and be well equipped, especially with tools as commonly need as a sat. meter.
bobrap said:Sorry guys, didn't mean to start anything. Just figured if the best the installer can do is eyeball it, I can do that one afternoon myself and then I can't complain.![]()
Limited time offer
