Question for "Mad Scientists" | SatelliteGuys.US
  • Thread starter Thread starter kenny4269
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
kenny4269
52
WI
How difficult would it be to modify a SD121 to pick up 118 and 129 only?
I currently have a SD121 an a pole mount. A friend recently upgraded to a 211 + Dish1000 and the installer tossed his SD121 off the roof and told him to trash it.
The dish is actually in descent shape, the top edge of the dish is slightly bent, but fixable.
I already have a DPP44 hooked up, I just need to pick up a couple DP21s if this is doable.
What problems am I likely to run in to? Is it possible to mount two SD121s on the same pole?
TIA
What channels can I get at 61.5 degrees?
Poll: Are you having HDMI problems with your 211/411/622
