Question for the pros... | SatelliteGuys.US
cr0mag
414
New Orleans, LA
Ok, here's my latest entry into the dumb quesiton book...
What is the real difference between RG-6 and RG-6 Quad... I assume that the Quad has more shielding insulation??
Secondly, what would determine the need for RG-6 vs RG-6 Quad? Is one better suited to certain environments?
Help....... :confused:
quad is USUALLY swept to 3 gig
quad has more shielding and is ideal for blocking outside signals, like when running 18 or so bundled wires together
RG6 quad-shield 75 ohm coaxial cable for TV, CATV, SATV and CCTV applications. Low-loss for use on long runs. Aluminium braid and foil shield. Gas-injected (foamed) PE dielectric.
More shielding means less interference and longer runs.
Quad
No, quad wrap isn't necessary. I see the cable companies using it so I guess they have interference problems we don't have.
CableTV in the U.S.?
1/3/05 Satellite Expo 2005 News & Notes
