Question in conflicting information from tech on ext tb hard drive | SatelliteGuys.US
iceshark
533
Pacific Northwest
Did not want to post this in my installation thread.
While installer was here he saw I have a couple external USB 2 1tb hard drives I used on my Tivo with Directv. Actually 1 is brand new. (picked them up on the cheap at Staples last Xmas black Friday for 39 bucks each)
He said are you going to use one with the Hopper. I mentioned I had read that it wont work yet or people have not been able to get it to go.
He said at there office they have a ext plugged in to test and it plugged and played and did not need a dish software install for ext drive.
So before I plug this in and blow up the hopper LOL. Anyone have a correct answer here?
Thanks guys.
UPDATE, As you said. Plug and play. Plugged in to USB. Found EXT drive. I let it format it. Now sees it when I choose DVR. However another question. Does it automaticly change to recording on the EXT drive only once internal is filled/? With my Comcrap box I could choose internal or ext to record on. This appears not to let me use the ext but I can see it with 99% room remaining. Its a 1 tb drive.
Thanks guys.
Dish will always record to the internal drive. You can transfer what you want to archive to the external drive.
I am upgrading from a VIP 722, if I am right I read that I can just plug in my external drive and view my recordings from it via the hopper.(no formatting) I guess my only other question would be can the joeys connected to the hopper view whats on the external drive ?
yes. it works fine .
Sent from my MB855 using Tapatalk
Sorry I am an idiot. I did not see you can scroll down to a third line in Menu. DOH! I see it and it works. How come it says Hopper has only 500gb drive? I thought this was advertised as a 2tb drive? my ext shows correct 1tb.
Dish reserves the rest for PTAT, and VOD.
Sorry if this is already in another thread-but having an issue with recordings transferred to EHD from 722, back to Hopper...I would say 1/2 of my recordings show the standard, "you're not subscribed to this channel message" when trying to play them back. Called Dish and they have placed a ticket for engineering...anyone else having this? Any updates or how to fix?
issue with sling adapter and android phone
Can the Hopper replace an AppleTV/Roku used for local content?
