Question on HDCP | SatelliteGuys.US
Question on HDCP
cal87
SatelliteGuys Guru
Cutting Edge
Aug 3, 2005
121
Tracy, CA
I have a 24" Dell monitor for my computer which is non-HDCP compliant. I also have an H20 hooked up to this monitor with both DVI and component. The only channel which seems to use HDCP at the time is 201. However, I cannot view anything when using component inputs either on this channel, at any resolution.
I thought that HDCP only applied to digital inputs. Why is it not working through component?
It's not a big deal now because no other channels seem to be affected, but anyone know if there are any plans to use this in the near future?
Channel 201 is hollywoods vision of the near future, where component will be downrezzed or turned off. Join the EFF.
AT9 and receiver question
Switching back to Directv
