question on legacy lnb | SatelliteGuys.US
nmfiredawg
256
4
Ok trying to check something in my area, and want to see what signal I get on 129. Was thinking of setting up my dish 500 dish with a single lnb to check signal strength.
Can I use a legacy lnb for a 211K to see one sat? Or will the power put out to the lnb from the receiver blow it.
If I get the reception than will use a bigger dish for 129 and switch it with 110 and 119
Yes you can use a legacy with the 211.
118.7 and 61.5
Error msg 129 about rcvr not yet authorized on a prepaid sys
