Most of my local subnets of course are in SD, 720×480. Comet shows 544×480. Tv show on has black bars on sides on Comet, but so does the show on Charge! and it shows 720×480. What is the difference in 544×480 and 720×480? Thanks
It means that Comet broadcasting at 544 x 480 has a lower native resolution and thus PQ, with pixels that are about 17% wider than they are taller within a 4:3 frame.Most of my local subnets of course are in SD, 720×480. Comet shows 544×480. Tv show on has black bars on sides on Comet, but so does the show on Charge! and it shows 720×480. What is the difference in 544×480 and 720×480? Thanks
Both ...Is the “HD” standard both resolution *AND* picture size? Or just resolution? I get into debates with a friend of mine over this sometimes.
For instance, a channel could have a high resolution but only display a 4:3 picture in the middle of the screen. So is that HD?
Both ...
But HD has higher resolution and a different "picture shape" or 16:9 aspect ratio ...
Not necessarily a different "picture size" as both 16:9 and 4:3 screens can technically cover the same sq. units of area. as demonstrated here with a 55" diagonal screen TV in 3 different aspect ratios.
television aspect ratio - Google Search:
Though this is for illustration purposes only. As I can't see anyone today making a 55" diagonal 4:3 screen.![]()
Yep ...So it has to be a higher resolution and 16:9 shape to be called HD?
It all depends on the capability of your HDTV.
As Trip points out, for SD broadcast I certainly agree ...Vertical resolution @ 720 lines, but horizonal can vary widely and sometimes the pixels are not square.
Limited time offer
