Question on Receivers | SatelliteGuys.US
wcalifas831
62
CALIFORNIA
Does this normally happen or is that how it is? I found galaxy 10r bird and ran a blind scan with one receiver. I tried a manhattan 1000 skyline receiver that doesn't have the blind scan also. The blind scan receiver picked up about 30 channels, while the Manhattan one only picked up like 15 channels. Anyone know why that would happen. I tried rescanning with the Manhattan and it said it did not find any new channels. The singal is at 80-82 with quality of 96-98%. Any thoughts?
if the manhattan doesn't have blind scan it won't find them , but you can probably enter the transponders manually
most receivers signal levels differ slightly between each receiver brand.
thanks
I went along with your advice and added the transponders and all the channels appeared. Since I'm a newbie to all this, little by little I get the hang of it. Thanks for your help
your welcome :) even after all the time i spend here reading i still learn new stuff daily :)
its a great site and a good group of folks :)
enjoy
Stab motors
Which LNBF to buy ?
