question on receivers?????? | SatelliteGuys.US
vargf
47
I like to know what smart Freq scanner recever is a good one because
on this days freq change with out notice and is dificult to get back channels
on SCR the providers change the the SCR and some times the channels stiil in the same satellite but with difrent SCR please can any body tell me witch one
is better I saw the pansat 2500 with the smart Freq I don't know.
I have a pansat 500IC with slot card but this one don't have a smart Freq scanner so this is no much I can do thats why I need your advece all.
thaks :confused:
WHOA....punctuation next time :)
Check out the review section. If you like Pansats, I recommend the 3500, 2700 or 2500. All have smart scan
The Coolsat 4000 is another one with a good blind scan option. All will help ya find those weird frequencies :)
Maximum cable length?
Whoa!
