Question.?? | SatelliteGuys.US
Question.??
joecap1946
163
Wewahitcka, Florida
I recently got my locals is HD. I am in the Panama City DMA.
I have a Samsung 52 inch LCD. I have the picture option set to "just scan".
I'm seeing a white bar at the very top of some of the broadcasts, hard to explain it appears to have some slight movement at the top as the program continues. When I change to TV setting to 16 x 9 the line disappears.
Is this an issue with my TV, Dish, or my Local broadcasts??
I don't have a problem watching the TV in 16 x 9, the PQ is crisp. Just curious as to why I'm seeing this line.
Thanks in advance.
It's part of the broadcast signal, the text info, etc. Some programs don't have it formatted properly to only view the image instead of the non-image info that is also transmitted on that channel. If you can change the tv setting or the receiver setting to 'zoom' or something else and get rid of it, great.
I watch most everything in 16x9 with my LCD. Why not leave it in 16x9 all the time?
That's what I'll do.
I was just curious as to why I was seeing it in the first place. Thought it might be a problem with Dish or my locals.
Thanks for your quick reply bebop. I appreciate the input.
You are welcome. I've had my 722 for over a year and have never used it other than in 16x9. The format is better for the large LCD tv's.
Is there anyway to vie OTA channels on deactivated 622
software level 6.22 on dvr 622
