Question | SatelliteGuys.US
Question
TREY_R
4
Can you use a direct tv dish for dish network?
and..........does it matter what model of reciever you have?
Welcome to SatelliteGuys... and yes you can, as long as it is the 18" dish... the lnb is what is called a legecy as opposed to the newer dishpro lnb's that are not compatable and will not fit the D* dish. Note you will only be able to get 1 Satellite with the D* (direct)dish. Better to find a Dish 500 to get the 110/119 combo.
copy mpeg from the 522 / 625
New mount/strut kits are a hazzard
