Quick help! | SatelliteGuys.US
Quick help!
jself1982
1,272
South Carolina
Well not an emergency, but can you use a Dish 300, w/ DishPro LNB to get 129? Where as 129 has a poor signal on D1000. If so, what is the way I could make this thing work, my zip is 29642, and there is no skew on this dish mount, but there is elevation markings, however I can make this dish do what it needs to do to be turned and angled to get 129 if this is possible. Thanks. :)
Yes, it will work fine. If you're looking to improve a D1000 install, just yank the DP-Dual from the 1000 and mount it on the D300 (or even better, a D500 with I-adapter from DishStore.net). Now just "stretch" the jumper that runs between the two D1000 LNBs and you're done.
By "sideways" he's referring to the skew, which is unnecessary with a single circular LNBF. The skew is necessary on the dishes with multiple LNBFs because the elevations for each satellite are different, one side higher than the other.
Need 622 diagnostics/counter screen info
211 and Winegard power supply!
