Quick Reply Glitch | SatelliteGuys.US
Quick Reply Glitch
Not open for further replies.
cdru
Just another yahoo
1,117
Fort Wayne, Indiana
If you type out a quick reply that has multiple paragraphs and then select the Go Advanced feature, any extra line breaks between paragraphs are eliminated. This causes two paragraphs to be displayed together without a extra line in between them.
For instance:
Paragraph 1
Paragraph 2
becomes:
Paragraph 1
Paragraph 2
So which editor should I use then? With any of the 3 options, it does the same thing. If you have a multi-paragraph quick reply and choose Go Advanced button, it formats the posts correctly. However the text box on that page has the extra lines removed.
I also edited my original post to show how it looks. I noticed it did it to my original post.
Try this:
Before pressing the "Go Advanced" button, click on the
("Switch Editor Mode") button in the upper-right corner of the text box. This will switch the editor to the WISIWIG mode. After that click "Go Advanced".
new customer registration
SatelliteGuy of the Year
