I've got a quick question about this setup.
Currently, I have a fortec Classic hooked up to a HH120 and then BSC621-2 (22mhz). Slaved of the Classic NA is my twihan card, which has a GI2650R slaved off it.
On the side, I have now a Fortec lifetime Ultra (freebie
) to replace the satpro rec for IS-9 and AMC 6 (both universals now; disqec).
What I'd like to do is find a way to hook up the IS-9/AMC6 to the Twinhan incase a 4.2.2 or HD feed shows up on those sats (and to stream a channel to myself at work).
Running cables out to the 120cm so all 4 sats are off the same disqec before the motor is not a option right now.
So, I was wondering this: Does the loop out port on the Fortecs block incoming 22mhz and disque commands when the receiver is on? If so, couldn't I put a 22mhz switch for the two fortec loop outs to the twinhan? If the loopouts don't block it, what about a DC block instead of using the loopout?
The 22mzh tone from the twinhan wouldn't pass the switch and the receivers would be providing LNB power and switch control.
Is this crazy?
Is this crazy?
