You might also want to consider wireless transmitters. I use them to send the output from the TiVos back and forth between TV's, and they're pretty effective. Radio Shack carries them for around $99.
No you can't. Tivo's will only output one signal at a time. It has two outputs,but the same signal goes through both. He suggested a wireless transmitter so that you can transmit the signal to another room where you would have a vcr and another tv to view it later.
I wish that Tivo's would record to vcr and let you watch another program(live tv),but they don't.
