Does any one know if it is possible to see the Guide with one time press. Now it is after two.
I also saw "press the Guide on the unit and then press and hold Active and let go". But I believe that was for R-20. I tried it on R-15 and did not work.
Doesn't the R15 have a Guide button on the remote? Or are you trying to ask something else?
If anybody finds out a way please let me know..
Yes, I was asking about, if you press Guide on the remote, it should take you directly to the channel guide and not the filter screen. So there is a solution for the HR20. But what about R-15 ?........The software up grade, is it some thing DirectTv still has to come up with or is it already released and I have to do download some thing ?..
For which one?.The R15 would need a software upgrade.For the HR20 it's described over at DBSTalk.![]()
First my apologies for the thread necromancy.
I seem to have lost the default guide filters on my R15 after a power cycle of the box. I have a probably weird request as to how can I get those guide filters back?![]()
I'm at work currently, so I'll try a reboot when I get home.Will a reboot fix this for you ?
Jimbo
Jhone,
This info IS available here, I know I have posted it at least once and others have as well.
Do a search and you will find this info.
I have no problem with dbstalk, but why go elsewhere if the info is already here ?
Jimbo
The CE planned for this weekend was cancelled, but it was to have the toggle to go directly to the guide. It will probably show up soon.
Limited time offer
