R-22 Problem | SatelliteGuys.US
R-22 Problem
zolr0a
miami
I have a DVR R22 on a single dish pointed to the 101 satellite. When I test the signals, most transponders come in at 80 to 95.
However, if I leave it to boot, it remains on acquiring data from satellite.
What am I doing wrong?
Is the box set to the correct type of dish? Is it set for two cables from the dish, assuming there is two, or set to one if there is only one?
Are you sure you are pointing at 101? If you are pointed at the wrong satellite, the signals will look strong but the receiver won't acquire DirecTV.
Tilt off 2 degrees
Trouible with DirecTV installed Dish
