r15-100 power button issue | SatelliteGuys.US
ry_an
usa
my neighbor dropped his r15-100 off asking me if i could take a look at it... when i plug it in, the harddrive spins up, but the power button does not turn the unit on. i've opened the front panel and the box making sure everything is connected and the button is making contact with the board that actually has the internal buttons (behind the outside buttons).. everything appears to be fine. anyone have an idea as to what i could do/try next?
Try both IR codes on the remote, 00001 & 00002, if still doesn't work, if the remote is RF, see if marrying the remote to the receiver by putting into rf mode:
1. press and hold MUTE & SELECT for two blinks
2. enter 9 6 1
3. press CH UP
4. enter the last 6 digits of the receiver ID #, found on a sticker in the access card compartment
5. press SELECT
The R15 is probably a lease if it dosen't power up frpm the front panel call Directv for a replacement probably will cost a shipping charge unless you (he) have Protection Plan.
Possible to install DirecTV dish on Dishnetwork pole?
