Radio channels 87W Cband | SatelliteGuys.US
Blindowl1234
2,035
94
SouthWest Ohio
Anyone know what happened to the channels on 87W? Tp info 4043 H 7140.
They were loaded in my Fortec for quite a while and today I get nothing on any of them. Thanks Blind:)
Coolsat 5000 seemed to skip it on a fast scan but worked on a detail scan
Pansat & Geosat picked it up right away but took forever to scan in since there is no "name" for it
Ice, Something is still screwed up in my Sathawk. If I manually enter a TP the TP numbers etc...are way off. Not even close to what would be shown in Sat Guys "The List". I'll scan then in the Fortec tonight and at least I'll have them there lol. Thanks for the help Blind
Desperately want to listen to Moody radio on amc3 87w
Have a traxis 3500. Locked on 87w receiving inn and zns Bahamas. getting only one radio channel . tried manually entering pid and scan no luck. please advise if moody radio still here.
Herbert, I don't know. I get all the Tv channels, but only the one radio channel you mentioned...I finally gave up trying to get them. I had them all before they switched Tp's. Maybe someone else has had better luck.....Blind
yes it is still there. Just scanned it in this weekend on the Pansat
same coordinates posted above
Programming Centers Response on G3
6 ft fortec star
