Radio Channels | SatelliteGuys.US
Radio Channels
satcustomer
304
California
Have a Fortec Mercury II receiver. When I do a blind scan, often some radio channels usually store. How do I listen to the radio channels? I see there's a button on the remote labeled "TV/Radio", but it doesn't seem to get me anywhere.
If the TV / RADIO button just defaults back to the TV channels try this .....
Press OK / LIST button then the TV /RADIO button, select RADIO button, then OK. Now you should be able to switch between TV and RADIO using the TV / RADIO button.
If they're logged as radio channels in the list, the TV/Radio button should work.
Some radio stations log as 2nd audio's on a TV channel so you have to pick 2nd audio (there are 3 on G10 that do that)
Channel Question
Parts for Stab HH 90
