sdsumann said:WeeJava, I'm in Fontana for point of reference I am right where the 15 / 210 interchange is. I have the SBC/Dish deal where I have two satellites. I have checked the signals before and one satellite (I cannot remember which) has some numbers up to 120's but over different transponders it is drastically different as low as the 70's.
Since you are relatively close to me I would assume that you should have very similar numbers as myself. I do not believe that it is an issue with wet connectors because all connectors are compression sealed and the switch is under an eve. WeeJava just for reference what kind of numbers do you get for signal?
I do think that the installer (dish employee) did a bad job of aiming because he just put up the sat and sort of eyeballed it, he never checked the signal level before he left. I mean the signal was not down for 2 entire days, just a majority of it, then it would come back then out again, frustrating to say the least.
AJ. I notice you keep talking about using transponders 10 & 11. Not good. Use 11 & 12 instead. 110-10 is a spotbeam, and will throw you off big-time depending on where you are.ajohnson said:I'm in Riverside, never had rain fade. You should check your SS on transponders 10 & 11 on satellites 119 & 110. Both should be over 100 on units that have a scale to 125, or over 90 on older units. If you don't see that then you probably need to re-aim. It gets pretty windy out your way, I assume you haven't lost the signal during high winds? That would rule out any mounting issues.
Limited time offer
