HelloJust obtained an additiobal remote for my H20. It's an RC64. the original was an RC32. What is the difference? I cannot find any.
the volume keys NEVER work initially with ANY audio code, not until you do the following. First there has to be a tv code programmed to the tv device or the volume keys won't work. then:
1. av1 or av2
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 3
4. press SELECT
Limited time offer
