RC72 Remote Control | SatelliteGuys.US
RC72 Remote Control
NutFlush920
960
2
Green Bay, WI
I need a new remote control for my HR 21. Does the new RC 7x series remote controls work with the older receivers? Amazon has them for $6.50 on Prime. Just wanna be sure before ordering
They do work, and they look nice. But they suck. If you're itching to get a new remote, get a nice universal one for about the same price.
Call D*, the will send you the old White on when you tell them what recvr your using .... mine was free and here in a few days.
The RC7x will control the HR21 just fine but ONLY on IR, if you need RF you MUST use the RC6x family of remotes
Genie remote Panasonic TV compatibility issue
Equipment Upgrade Question
