RC72 remote disassembly | SatelliteGuys.US
sportflyer
31
4
Vancouver, WA
The key "0" is getting to be inconsistent. How do I open up the RC72 Remote Controller to clean the keys ? How many additional screws are there besides the one in the battery compartment ? Tks
Why not just call and have them send you a new one? Just being polite will get you a remote typically.
I did try very politely to request a replacement but the customer service rep. want me to buy a new one from them at $15 . I can buy 2 from ebay at 1/2 that cost. Still its fun to be able to disassemble the unit , clean the contacts and refresh the conductive rubber button with some contact fluid.
Call them back ... they normally have no problem sending new ones out.
Then tear it apart if you want.
I have not looked closely at one seeing I don't use one, but I'm wondering if they are glued instead.
Never opened one, but my guess is they use the clips that the top/bottom attach by pushing together. Anytime I try to open something with that design I break too many clips and it never goes back together as sturdy as when I started it. You can get a two pack of the remotes for $10 shipped generally, one to use and spare too, I'd order that, in the event your repair doesn't hold up.
I have been trying to open an RC66RBX remote to cut the trace of the "ACTIVE" button. It's in a bad place and I am constantly pressing it and it's not a quick process to get out of it. There are 2 screws on the bottom underneath the battery cover but for some reason the 2 halves won't separate.
With a Gene HD-DVR, can you do this?
Alternatives to Locals Pulled in Palm Springs Area
