RE: DishNetwork & DirectTV equipment | SatelliteGuys.US
Devros
4
Orinda, CA USA
Does anyone know for sure if equipment (I guess its called tuner box), will work on:
1. Component connectors
2. Composite connectors
3. Coaxial
I ask because none of my TVs have HDMI, DVI, Display Port, etc.
Depends on the model
Are you feeding SDTVs?
Dish SD boxes will all have composite and coax outs.
Anything can be hooked up to an SD tv with the right adapters.
Directv HD have HDMI, Component, or 10 pin adapter(for component) on the smaller receivers
