Re install Glorystar software on a Mercury II ? | SatelliteGuys.US
rv1pop
I was able to retrieve my Mercury II that someone "borrowed" from me. :)
It now seems to have some sort of hackware on it that makes it almost impossible to use. Is the Original Glorystar firmware/ software available to reload? (ie. 2222 for G-19). Or even better a complete up to date channel list included. Thanks!
I might be overlooking something, but I tried what I remember as Factory reset and it got worse. :confused:
The only thing I know I have not yet gotten back is my pressure washer.
Pop - try Menu/Factory Reset/Factory Reset Press OK/Yes/Menu/factory Reset (OK button one time only)/3030/("Do you want to load special data") yes.
Bob
Really no reason to reinstall old firmware, since a large majority of the channels have moved since the final MII update in 2008(????). Would be faster and more accurate to blind scan then delete and reorganize.
Glorystar Mode with a DiSEqC switch?
What is a good editor for the Glorystar DVR1100c
